I was told by my dealer to download android auto from Google play store which I did and then connect my android phone USB cable to usb data port which I did, but my phone still doesn't work. I have a Note 8 SM-N950U.
Does anyone know if my phone is compatible with my truck. 2016 LTZ
Do you have the window sticker? There was a shortage and several vehicles received a credit for not having the updated interface. What is the RPO code for your system and is there an RPO code "CPO" listed?  In the upper glove box.
4 hours ago, Bharpmaintenance said:
It was manufactured 01/16
You probably don't have the capability.  Like Timayz said only the later-build trucks had the right HMI and even then the dealer had to do a software update to enable it.  If the truck was an earlier-build with the 2015 HMI the original buyer was given a small cash rebate or discount on accessories to make up for it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
