2001 1500HD DRL and AHL issues
I have an 01 1500HD with about 110k on it. I have owned it for 1.5yrs and when I first got it the DRLs and auto headlights worked properly. A while back I started having the headlights turn on evertime I started the truck (day or night) and have to do the dome override all the time.
I have done a ton of searching/reading and done the following:
I changed DRL bulbs - nothing.
Sockets looked burned so I changed them - nothing.
Checked fuses and swapped relays - nothing.
Put a new ambient light sensor in - nothing.
Finally tried a new headlight switch - still nothing.
Pulled the BCM to see if there were any cracked solder joints or anything looked burned - nothing.
Tried cleaning ground points and ran a few redundant ground lines for battery/body/frame - nothing.
Codes from the BCM are:
B1477
B2585
B2617
B2647
B3102
I dont seem to have any other weird electrical issues that would lead me to believe the BCM is bad.... Does the Ambient light sensor route thru the BCM and headlight switch only or does it go thru the HVAC controls as well?
Any other ideas? I would like to avoid paying to have it fixed if I can do it myself, but I am at a loss.
Thanks!
Another question...anyone have a pic of the ground point under the dash on the drivers side? G203 possibly?
When I had the dash cover off I found the ground point on the passenger side with two smaller wires. Cleaned up that connection with no change.
Looking on the drivers side I could not find anything that looked like a ground connection under the dadh cover. Checked behind the light switch/AC vent and even behind the kick panel near the floor...nothing.
Passenger space for this gen has 4 ground points. 200 series are the dash area, 300 series are seating space, 400-800 and higher are doors and farther back.
FSM shows two dash points. Either end, bolt faces up, on rail, near the A pillar.
Two body points. One under the driver seat for use the power seat circuit. The other is on the driver B pillar some 6-8 inches up (older GM's had this hidden under the door/floor trim)
Thanks...is there a diagram by chance? When I had the dash cover off, the one on the passenger side at the base of the A pillar was easy to find. I looked pretty extensively on the driver side and couldnt find a stud or anything that looked like a ground point with anything attached.
Is the one at the bottom of the B pillar just for the seats?
Thanks in advance!
Per FSM, the dash ground points are located on the upper support rails for the dash. It's a upward facing bolt.
The two dash ground pretty much split the dash and door grounds
B Pillar covers the rear doors and beacon lights on pickups
The ground under the driver seat covers the seats
(Generally speaking)
Found it. Down a little deeper than I was looking the first time. Cleaned it up and still no change. Guess I will have to take it some where for a diagnosis.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
