dash
There’s a pdf link in this thread below shows where the bolts are. Also read this thread since you didn’t say why your taking it apart if your only replacing the cover you don’t need to tear it all the way down.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
