Floor Jack Rebuild
This may be off topic, but here goes.
My trusty 2 ton floor jack has blown a seal. I would love
to rebuild it instead of buying a new one.
Does anyone have any advice on where to buy rebuilt
kits or get instructions on how to do a rebuilt.
Has anyone had a jack rebuilt before?
Thank You
Joe
Find a Hydraulic Hose and fittings shop in your area, and see if they have someone they can send you to, or do it for you. Possibly even a machine shop can clean up anything with grooves in them to help the new seals do their job.
Been there done that!!! The first question to ask is what kind is it? If it is a "Name" brand you can have pretty good luck getting it fixed but if it is an import best thing to do is just buy another one. I spent about 3 weeks chasing kits and o-rings and other things to rebuild one, and after everything was said and done first time I went to use it started to lift then puked :P it guts out again!!! I think I spent about $50.00 to "fix" it then bought a GM Goodwrech at O'Rileys for about $65.00 and that was 5 or 6 years ago and haven't looked back.
What would you recommend for maintaining a floor jack? I had an AC-DELCO that came in a case and broke. Now I've got a regular floor model. Is there oil to add or??
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
