My passenger side mirror wouldn’t unfold with the fob or the switch on the door. So I manually unfolded it this morning. I’ve tried re syncing it but that hasn’t worked. I sprayed some lubricant in the mirror also. Can the motor be bought separately or do I have to buy a new mirror. This is a 2015 HD
Edited by CruseMissle
I used to have a 2014 GMC 1500 AT, I now have a 2017 GMC 1500 AT.  On both trucks, the passenger side mirror would only power fold when it felt like it, about 1/3 of the time.  Sometimes I could just hit the button a couple of times and then it worked.  On the 2014, I took it back the dealer and because it was intermittent, he couldn't find anything wrong with it.  So yeah, strange stuff.
These motors can be purchased. I looked into it at one point when my passenger mirror motor failed after about one year. I had it replaced under warranty though.
Have you tried to re-sync (reset) them? ...like if one is manually pushed in and now they are out of sync. Don't know if this will help with your problem, but it's always worth a try before replacing a motor...
The reset process seemed relatively...but I can't remember if I saw it on this forum or the Duramax Forum? Or, possibly it's in the owners manual?
Edited by EJCarter
Disregard - just re-read the original post and re-syncing was already tried...
I had a similar problem, and had it replaced under warranty. At first GM/dealer couldn't reproduce so I send them video.
Sent from my XT1585 using Tapatalk
Here is one mirror parts example: https://www.gmpartsdirect.com/auto-parts/2015/gmc/sierra-2500-hd/slt-trim/6-0l-v8-gas-engine/electrical-cat/mirrors-scat
It’s making a nasty noise I’m assuming something is broken inside. It won’t reset either. Looks like I’ll be buying a new mirror soon
Contact this company:
http://www.gruvenparts.com/gruvenparts-com-strengthened-spur-gear-for-2007-2014-gm-trucks-folding-mirror-assembly/
This motor is for an older model, but the page says 2015+ coming soon. Who knows when that was, but maybe they can help you.
EDIT: Here you go. Says it's a pre-order.
http://www.gruvenparts.com/gruvenparts-com-strengthened-folding-mirror-gear-for-2015-gm-trucks/
Edited by 8lugCT
Thanks I’ll look into it.
I called them, if its for the towing mirror, they have the replacement gear only but its not really listed.  Just email [email protected] and he can sell you replacement brass gear section to replace the stupid plastic thats failed.  Its cheap and its probably all that is wrong.  These towing mirrors are stupid expensive and mostly good except this.
Actually, this doesnt sound like its a tow mirror.  It is the same gear and motor used in the 2007-2013 trucks, it just has a slightly different housing.  But the link I gave you above would work for 07-13 power folding gears.
  • 4 months later...
  • 5 years later...
How do you replace the motor and gear?  Can't find any instructions from Google.  Thanks
Yeah so my passenger side mirror wouldn’t fold out. Pushed button again usually works   But this time, with my 63 yr old friend and 5 yr old child in the truck!! The damn thing caught on fire started smelling & smoking!!! I jumped out dumped my cup of what was mostly ice on it then grabbed this man’s hose turned it on ran to my truck & sprayed the heck out of it. I was in the middle of south ga so I needed it to get back on the highway. Thank fully the cameras worked so I could change lanes a tiny bit safer & finally home around 11pm. They want $1,425 to replace it. It’s just the motor is there a recall? What can I do? I’m in a huge bind with other unfortunate events simultaneously occurring (hence the over emotional tone above). I’m still trying to find a job on top of this. Can anyone help me get one win?
2021 Chevy Silverado 2500 high country so just fell out of warranty
Edited by Mdymdskppr
Model year correction
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
