Z-height and wheel alignment
02 Silverado 1500 ext cab. 160k. 5.3 4x4
I need to make some minor-moderate z height adjustments using the torsion bar key screw.  After driving with replaced front suspension for quite a while with wheels aligned, everything is good.
I noticed I’m a bit too squishy and floppy and measured the z height to stock specs and I’m just a bit low.  Also, my sides are not equal even taking into account nearly full gas tank or empty
So, will torquing down the torsion bar keys to get me back to stock specs require a new alignment?  I’m maybe off 0.5 inch one side and 1 inch other side from wheel arch to ground floor.     I can pull up the actual z height measurements if that’s needed. I tow a 4,000lb camper so I don’t want to mess with something I don’t need messing with too
