Hello all. My next issue with my 96 Tahoe is the heating system. It blows good heat just not enough. The blower motor is running fine but not much comes out of the defrost vents. Any ideas would be greatly appreciated!!
Do you have good airflow from other vents? If all have weak air check your cabin air filter, if equipped.
There are several actuators that control airflow direction as well as temperature also
