Airbags - install single or individual schrader valves?
Move Over
It just doesn't happen that way.  That's not how airbags work.
First, if you've ever filled one or let the air out of one, you know with the line sizes commonly used in these kits it takes a long time.  The pressure will equalize eventually, but it will take a very long corner--skidpad like--(or as I mentioned, slowly crawling over rocks or uneven terrain offroad if you stop for a while) for the pressures to equalize.  In dynamic maneuvers, it's a non-issue, there will be no measurable difference.
Even ignoring that and assuming for a minute the pressures would equalize instantaneously, don't take my word for it, look at the data for yourself:
That's the actual data chart for the bags in the Airlift 5000 system, some of the most commonly used on these trucks.  If you compare the graph on the left to the graph on the lower right, you can see how the bags act in each scenario.  With them connected so the pressure equalizes they'll act like the chart on the left in pure roll.  You can see their spring rate is much more linear than on the right, but it's still just a spring rate.
If the bags are at 6" static height and under roll the outside is compressed 1" its load will increase by a certain amount depending upon the pressure at which it started.  And the one on the inside, which is extended by 1" decrease its load by a similar amount.  Just like your leaf springs or any other spring.  They will act no differently than an added set of springs.  They will add roll stiffness, not subtract from it.
Conversely, if plumbed separately, a very similar result occurs, just bigger as the outside bag gets into more of its progressive range so its load increase will be higher and the pressure the inside bag will be reduced a little so its load drop will be bigger.  The result is similar--they add roll stiffness, just more of it.
So no, they will not "compound the lean" in either scenario.  Both methods will add roll stiffness, reducing total roll, adding stability.  One just more than the other.  It's like comparing a large swaybar with a smaller one.  Just because the large one adds more roll stiffness, that does not mean the smaller one actually makes things worse and increase the roll.  It doesn't.
And again, that's assuming you're circling a skidpad or the like.  For dynamic handling and most real-world corners, the above is largely moot as there's not enough time to exchange the air between bags for people to even notice a difference in handling between the two setups.
Or we can look to what Airlift recommends:
https://www.airliftcompany.com/workshop/single-path-vs-dual-path/
Gee, thanks.  They recommended exactly the same thing I did in my first post.  What they didn't do is agree with your contention that plumbing them together is "dangerous" in any way.  Because it's not.
Golly, you’re welcome [emoji106]
They literally state “dangerous travel” verbatim but I don’t read to good.
They say hauling a camper is dangerous.  Not that their airbags are.  It's quite clear.  They say the dual path is better for that application, just as I did.  Nowhere do they say that the single path is dangerous in any way.  That's something you made up or got from somebody who did.  Because it's not true.
All the evidence and logic in the world will never change this guy's mind.  I mean, it sure must be dangerous - GM sold likely a million+ trucks/SUV's with a single path airbag system.  That system, though very prone to breaking, isn't dangerous at all.  If it were, there would be class action lawsuits over the last decade regarding it.  But let's not muddy the waters with facts...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
