My first GMC
flipper88
Howdy everyone. This is a bit of a long story but I’ll try not to put you to sleep! I just bought my First GM truck! I have always been a ford guy. In fact I just sold my last ford which was a 1996 F350 Crew cab long bed 4x4 with the 7.3l. I only do serious towing about 5 times a year so having the 1 ton and diesel didn’t really make sense. That and I’m at a point in my life where I wanted something more comfortable for longer trips. We spent the day going from dealer to dealer and looking at some private party trucks with nothing catching our eye. The only thing we knew is we wanted a ¾ ton 4x4 with a gas motor that was a crew cab and had leather within our set price.
We walk into the local Chevrolet dealer and after giving them the details they informed us that they didn’t have anything that met our needs. As we were walking out another salesman asked our guy about the GMC they had just taken in on trade. It was a one owner 2007 GMC ¾ ton crew cab short bed and was loaded with leather and all the options like console, dvd player, heated seats, etc. and here’s the best part, it only had 44k miles! As soon as I heard that I knew it was out of our price range. He said the bed was severely damaged after the original owner loaned it to a neighbor and since he wanted a new truck anyway he never had it fixed. He said they are going to order a new bed and get it all back together and ask mid 20’s for it. seeing’s how 20k was our max out the door price we thanked them for their time and walked out.
Later that day were taking a break and eating lunch and a thought occurred to me. So I called them and asked if they would entertain selling that truck before doing any of the work and what the price would be then. They said yes and we agreed on price and let’s just say it’s well below our max budget! What makes this deal better is I currently have a short bed flatbed sitting at home that I will throw on the truck in the meantime. I’ll keep my eye out for a replacement bed. Who knows maybe I’ll fall in love with the flatbed! The truck is currently at the dealer getting detailed and the new tires put on that I worked into the deal as well as their safety check. If it all works out ill have the truck by the end of this week and I’ll spend Sunday taking off the junk bed and putting on the flatbed!
Sorry for the novel, looking forward to learning a lot about this truck!
I'm dedicating Sunday to the bed swap. Ill take lots of pictures and share the adventure here!
Nice! I wish I just had a flat bed sitting around sometimes, ha!
looking forward to finished pictures.
26 minutes ago, Black02Silverado said:
Welcome to GM-Trucks.
Sounds like you got a deal.  Post up more pictures when you can.
Thanks! I will post as many pictures as I can of the process.
It was like it was meant to be! I like your plow set up! Where we live the snow would be gone before you could hook up a plow lol
Originally posted in the wrong forum section...
congrats!!  My favorite truck was my 08 Sierra 2500 Duramax crew cab long bed.  I miss it.
  • txab changed the title to My first GMC
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
