Alright friends. 2004 Silverado. How many actuator doors are on this thing? Depending on who you speak with, it can be 3 or 4. 2 on the floor, and either 1 or 2 up on top of the dash.
My money is on 3 total. 2 floor, 1 top of dash.
Do we agree?
Thank you ever so much. You are all scholars and gentlemen. Or ladies, i reckon. Haha!
That would be a manual climate control module. I just replaced the module itself. Dorman 599-210
Two temp actuators,one mode actuator and one recirc actuator.The drivers side temp  actuator is on the bottom.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
