Box lights
Nateb04
Newbie here guys, it’s prob covered somewhere but maybe not. 2018 Silverado LT with factory box lighting, is there a way to get them to come on with the exit perimeter lighting. The only way I can get them on is to turn the cargo light on? Thanks guys
In theory, you could wire them into the reverse lights (since those come on as a part of the "perimeter lighting") I guess.  The plug for the box lights is in a plug set just behind the spare tire, so you could cut and splice from there to the tail lights.
For me, I have a tonneau cover, so I want them to come on when I open the tailgate.  I have the lights spliced into the power of my 7-way trailer plug and switched by a magnetic switch so that they come on when the tailgate is opened.
Couple options, at least.
There is a way to do this through your vehicle settings.  My '18 LTZ ME came with them ON, I turned them off.  The only lights that come ON when I open a door is the "Puddle Lights" under my mirrors.  The vehicle settings had my headlights, tail lights, and cargo lights all coming ON, when I unlocked or opened a door.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
