0% for 72. Anyone get this?
  • Replies 34
IMO in the world of low interest rate loans, it makes very little sense to tie up so much cash in a vehicle. I do a fair bit of investing and in an average year make around 6.5% return. This basically means that my vehicle comes out free with a low interest rate loan from my credit union. Plus, one comes out ahead in terms of 2-3% annual inflation.
Agreed, paying less cash initially on a low or zero interest loan allows you to earn interest on the money you didn't put down on the truck. That way a $50,000 investment like a common mutual fund can produce a ROI of 2-6% per year, a pretty good deal if you are at 0% on your vehicle loan. If the cost to borrow is 0, then put as little down as possible and take the loan as long as possible, put the money somewhere where it will make you money rather than drop it all initially and hope to get it back at trade-in time.
I pay cash but at 0% why not play with my money with no loan penalty.  When I bought my 17 I made the deal cash and was at 27% off sticker after the usual games.  I asked them then if they would finance my deal at 0% and they said sure somewhat reluctantantly ... good enough for me.
I think they might be a little looser with it in Canada. Here in the US they typically make it an either/or proposition. Get X "extra" percent off sticker (ie bonus cash) or 0% financing. The theory is the customer pays the same money, just in a roundabout way. However, most credit unions give 1-3% interest loans, so one can take the bonus cash and finance through the CU.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
