Fuel pump went out after 3000 miles
farmboy1995
Hey everyone, just bought a 2018 GMC Sierra 1500 with the 5.3. I have had it for about 3 weeks and put 3500 miles on it. Today it started throwing codes and went into limp mode. The codes were P0090 and C0242. Talked to the dealer and come to find out my fuel pump went bad. This truck is used on our farm in pretty dusty conditions. At least 75% off road driving on gravel roads or through fields. The dealer is blaming the cap less fuel filler and says after 3 new fuel pumps they’ll try to convert it to a standard gas cap filler. Anyone else have these issues or codes popping up?
Hopefully you just had a fluck of a fuel pump does happen. Can't say i had the same issue but i never cared for the cap less filler. im from the Midwest and drive on a lot of back roads and gravel and i ended up just going to lowes and getting a pipe cover 2.5 will fit good and snug won't fall off by no means keep the filling area clean and don't see it causing issues now in my opinion.. Plus if you're from a area that gets snow it will at least keep the hole cover so when that area get filled with snow water won't be getting water in to the system as well. Only does that in blizzard and 40 mph winds at least in my experience. GM does make a locking cover but it a bit of a pain and lock breaks very easy missed the old set up on that one.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
