Gunslinger354 Posted December 5, 2018 Posted December 5, 2018 My truck is 17 LT z71 1500 with 3in front 2in rear level kit with a differential drop , i have factory 285 45 22's on it, ive seen many guys go 33x12.5 but can a 35x12.5 fit even if i use a wheel spacer?
14 Silvy Posted December 6, 2018 Posted December 6, 2018 On stock wheels a 35 should fit ok.Sent from my iPhone using Tapatalk
boyzzsandtheirtoys33 Posted January 6, 2019 Posted January 6, 2019 My current set up is a 2.5 leveling kit with 2 inch blocks in the back. I am running 295/65/18 and at full lock there is slight rubbing against the control arm. I installed some spacers and now there isn't any rubbing at all. I believe you could fit 35s but there would need to be a decent amount of cutting.
