Loud humming while accelerating
James M12
Hello
I just purchased a 2016 Suburban LTZ and noticed when I am driving and slightly press on the gas petal I hear a very low frequency humming sound, almost like a deep bass sound. You can feel it in the gas petal as I take my foot on and off the pedal. If I apply more pressure and accelerate, the hum goes away or if I take my foot off the pedal. Seems to be only when have very little pressure on the gas petal, maintaining my speed.
I saw the PIT5404B, and not sure if this is related or not, not sure what 'buffeting' is. But it's really annoying and just got the car, so I'm not sure what my options are.
I've seen other gmc threads about exhaust or front differential etc, but wanted to see if other have the issue or can point me in the right direction.
Thanks for any help.
James
There is a lot of owner information on this forum about your 2016 SUV on buffeting, pressure, shaking, and vibration.  No solid fix from the manufacturer.  As the years increased 2017 thru 2019, manufacturer trial and error could have minimized the impact of some of the effects.  You should read a few pages to compare with what you are hearing.  Slight chance something else is going on, but the way you describe it sounds like AFM is kicking in under slight pedal with 4 cylinders struggling to move the weight of your truck.  When you get off the pedal to coast or give the truck more pedal to kick in all eight cylinders makes sense that you would not hear a hum.
Zip,
Referring to the 4 cylinder cycle is exactly when it is happening.  Is it something that just needs to be accepted or is there a manufacturer fix for it?  Will it ruin engine?  Thank you
My personal opinion, AFM works better with lighter vehicles (cars) vs heavy vehicles (trucks).  I don't think there is anything mechanically wrong with the AFM process and the fix would probably be not to use AFM with heavier vehicles.  Or maybe make AFM drop 2 cylinders vs 4 in heavier vehicles.  Expect what you hear to get worse with the more weight you put in or on the truck unless you change your driving style with a heavier foot to decrease the times AFM transitions.  The process of transitioning from 8 to 4 doesn't seem like it would ruin your engine.  In a couple of months I would be driving my truck for 5 yrs, it's performing better than day one.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
