Just the fog lights are enough with LED
Does anyone else with the LED lighting use just the fogs to drive at night?  I'm constantly getting flashed even with low beams so I shut off the headlights and put only the fogs on.  Plenty of light for me and less annoying for others.
You can adjust the headlights.. If you have lift or level kit the headlight aiming will be off.
I hope you all adjust your headlights when you alter your ride height.
Sent from my SM-G965U using Tapatalk
I have a 4 inch lift kit and my low beam is extremely annoying to other cars , so mostly I use the fog light .
I need to adjust it after the lift but the car still new and I don’t trust any one to play with the light ( even GM dealer )
Any time you modify the ride height you must perform an alignment and headlight aiming..
Unless you are only worried about form and not function.
I m worried about form and function and for me my headlight low beam are perfect and gives great visibility but since they are led it is annoying to other that’s why I rarely use them
I would aim the lights so you can use high and low beams... So they function.
It's your ride..you do what you want .
Really?
If you get flashed a lot they are to high from your lift.
What don't you understand.
Driving with fogs fixes it?
Really?
[emoji4]
Dilly Dilly!
Don't be afraid to aim those headlights..
Find a level road, with no traffic and adjust until the high beam shines normal...Not the tree tops!
There is only one adjustment..Up and down.
My truck is not lifted or leveled.  When driving my car I can see why I get flashed when a newer Silverado passes me.
My ‘16 had the headlights adjusted too high from the factory. I got flashed multiple times by oncoming drivers the night I drove it home from the dealer. A simple 1 minute adjustment with a Phillips screwdriver fixed the headlight aim.
Nice.!
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
