2014+ aftermarket steering wheel
BlueTopaz14
Following a forum on Facebook I came across a post from a gentleman who created these steering wheels for the 2014+ Silverado’s. I’m not sure about y’all but I have wanted a much sportier steering wheel ever since I purchased my truck so I’m pretty stoked! What are yalls thoughts?
Side note: I talked to the guy and he said there will be other colors available he’s just not sure and they will have heating capabilities if there is enough interest shown
They look pretty cool. Price?
Sent from my SM-G955U using Tapatalk
No price yet! He’s just testing the waters before mass production lol I think they are gunna sell like hot cakes
Actually pretty cool I wish mine had the red stitching in the steering wheel and seats to match the redline edition package. Kinda like how dodge does it. I will admit GM does not put that much thought into thinking outside the box.
Those are pretty cool, i dont have heated wheel but would like too! Are all the steering wheel controls swapped in as well as the center airbag?
Correct everything just snaps back into place
That we can agree on, even the difference between the higher trims has never been anything too crazy!
Exactly my point I mean I love my truck but to say it’s a redline edition with only a few stripes on the rims red hooks and black and red badges. For 2100$ extra idk they could have made it more over the top.
there's already a company doing wheels like that. I think they were around 500-700 depending on options
Name? [emoji848]
Someone should reach out and see if they can set up a group buy for these things.  I like the OP design better but I don't think the red would be my first choice and they would probably sell better with a neutral color like grey or white.  I'm a sucker for carbon fiber  though so I could go for the SCgarage ones too.  I don't see <600$ unreasonable.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
