spots in black paint
I was looking at the hood of my truck the other day and noticed it was covered in spots. These things are about the size of Lincoln's head on a penny. They are irregular in shape but pretty consistant on the hood. Didn't notice them on the sides and didn't check the top of the cab. The truck is not quite a year old and black. The spots look like pearl specs or the inside of a clam shell. The clearcoat is smooth, so they appear to be deep and into the paint itself. Anybody have an idea as to what could cause this? I've used Maguiars paste wax about a month earlier and that's the only thing that's been on this truck. Is this what they call by chemical fallout, and do you think it would be covered under warranty? :flag:
Have a body shop look at the area and see what they think, usually "industrial fallout" will leave the surface area rough where the "spots" are.
I get them on my '01 black silverado after washing it. The only way I can get rid of them is by waxing. But they just come back next time it gets washed. This is only on the hood, nowhere else. Baybe the heat from the engine does it. Next time black wont be a color choice for me! Looks great after wash and wax, but a soon as it rains or driving in dusty areas, it looks dirty all over again.
They are water spots. Calcium, I believe. My Onyx Black Sierra just got a 3M power rub out, just for that. My well water is the main culprit but rain will do it also but to a lesser degree. I've even tried steel wool on the window glass but no luck. DO NOT EVER wash the vehicle in sunlight. After you do wash it in the shade, dry immediately. I use a water blade and the Absorber. Prevention is by far the best solution. It is not covered under the warranty.
JHM,
I know what you are talking about. They seem to be stubborn water spots. Kind of like something etched in the paint but they feel smooth. Waxing seems to take them out but like you said it requires a waxing everytime you wash it. I even tried washing early in the morning when the hood was not hot and drying afterwards and you still get some to appear. Only on the hood as well. I have not noticed them on the top of the cab.
thanks for the suggestions, I don't think they are waterspots though. I too have well water and know what water spots looks like. The waterspots are mostly white with a ring on the edge that is more white than the center and they sit on top of the paint. These things look pearl colored and almost rainbow like and they look like they are under the paint. I always dry the truck and haven't got waterspots since after the 1st wash where I didn't dry it and didn't know to. The last time I washed the truck was about a month ago and waxed it afterwards. Haven't had any rain since, just a few morning dews. It was starting to get dusty enough to wash again and I noticed the spots. This leads me to believe they are not waterspots. I haven't had time to wash the truck yet to confirm, but just rubbing some water on them didn't remove them, they look like they are embedded. We'll see.
bigtruck21,
What kind of wash are you using on the truck. I was using this one brand, can't remeber which one now, but it left rainbow looking marks or streaks even after drying with a cloth. LIke if there was too much soap in the mix and it didn't all come off or something. Switched brands and haven't seen it since. The water marks are a different story, I still seem to get those.
the blue armor all stuff. I didn't figure the soap would make a difference as long as it was auto soap and not dishwashing soap. I have used the entire bottle of this stuff and this is the first time I saw the spot, plus no spots on the bike. I did pick up some red eagleone soap just to check.
Could it be oil from a car burning oil in front of you. I have gotten that on my hood and winshiled in the past. And it was a black Caddy so it was all pearl colored as well. Just a thought.
Later,
Brandon
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
