If you will use the truck off rode more rubber is better. Think like driving over a curb, with the 18's you have more rubber to protect your rims. But honestly if you dont drive over curbs or large rocks go with what looks best to you.
I was planning on upgrading the tires to LT 10 ply tire, probably BFG ko2anyway to  about 34's.
  • 11 months later...
On 12/18/2018 at 7:24 PM, Ben Berkenpas said:
I test drove both before buying. I went with the 20s and the 275 60 20 Bridgstone Duelers. Ride so much nicer and handle way better. Don't look quite as aggressive but as an every day driver it was the right choice for me!
I don't think these wheels could look any better.  If I step into a 2019/2020 Silverado, I will definitely be getting a set of these rims!!!
I have since upgraded the tires to 305 55 20 BFG KO2
My 2010 has 18's, now I have 20's on my 2015. Miss the ride of my 18's everyday. Cheaper tires too. Just a little more body roll on the pavement.
  • 1 year later...
21 minutes ago, 19TrailBossCA said:
Thanks!  Didn’t think about the UCA’s…makes total sense.
Wouldn't need 1 1/2 ". 1/2" would probably be enough but.... go big or go home!😂
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
