Misc. NBS Part Sale
Will!
Some of you may know, I traded in my ‘05 and I have some leftover parts that I need to get out of my garage.
Upper and Lower leather replacement covers and seat bottom foam - The Seat Shop. I bought these direct from The Seat Shop to completely re-do my drivers seat but never got around to it. I would like to sell as a complete set, in brand new condition.
Medium Dark Pewter (light gray) OEM Vinyl/Leather
Would like to sell locally and as a set. Can ship at your expense.
$475
Brand new in the box Trex Billet Grille - Part 21100
Never opened, had planned to install but traded the truck prior. Can ship at your expense.
$75
Blackbear Performance AutoCal.
Used once to tune my truck prior to trade in. Nearly new condition in the box. Can ship at your expense.
$225
Help me get my garage back and fund the mods for the new ‘18.
Are those covers for both passenger and driver side? That pewter is the color I have in my 06 avalanche, assuming you either had a 05 silverado, sierra or avalanche, those might fit mine.
These are the upper and lower “covers” driver side seat only. Plus the seat bottom foam for the drivers side.
I had a 2005 Silverado. I checked the part numbers on The Seat Shop website and it will work with your ‘06 Avalanche.
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
