Lights won’t stop hyperflashing??
farrari
11 minutes ago, farrari said:
What is PITA snd if it does work stock then I’m back to where I started correct? And thanks for the help!
Pain in the a$$
Looking over the wiring diagrams, the LED and non LED have the exact same wiring and pinout from the BCM to the taillights, save for the addition of a voltage drop reference wire (I believe; it's a red wire on your factory tail lamp harness) for the LED logic module (inside the tail lamp) from the BCM to the taillight. So, if it were me, I'd take the aftermarket tail lamps and your extra harness, and wire the load resistors (2 of them per side) in parallel to the turn signal circuit and ground; then they *should* work properly.
23 minutes ago, SS502 said:
Pain in the a$$
Thank goodness for other old timers on here besides myself...….
Totally off topic, do you access to all of the wiring diagrams? There is a member on here having problems with his memory function switch and the seats, and he is trying to figure out if it is a fuse, relay, or ???
Are you saying two per harness then which would be two on each side or two per bulb which would be four on each side? I tried cutting resistors two per side only one into the ground wire and one into the power wire and no go. Could be doing it wrong still a rookie at this that’s why I’m asking on here and thanks to you and envying for the help!
One per bulb (2 per side; 4 total on the rear of the truck). Can you take a picture or tell what color wires you've spliced into? Also, you can verify the turn signal wire with a test light or voltmeter if that helps.
  • 10 months later...
Was this ever resolved? I'm having the exact same issue with the same tail lights. I have a 2018 High Country and I swapped the harness toa LT harness as well. Resistors aren't working. I'm about ready to give up and let it just hyper flash. I think the factory tail lights are ugly as sin...
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
