Lights won’t stop hyperflashing??
farrari
I have a 2017 Silverado 1500 High country with factory led tail lights. I bought aftermarket smoked led taillights. Lights are supposed to be plug and play and have resistors that come with and plug in but the company doesn’t make them for oem factory taillights. So I got new tail light harnesses for like an lt model and still have hyper flash. I bought plug and play load resistor harnesses for these harnesses they plug in perfectly but still hyper flash! What can I do? Can I have the bcm or ecu tuned to change the resistance as I know these new trucks don’t have flash modules
heres the links to the products I bought
tail lights- https://www.cjponyparts.com/led-taillight-black-housing-with-smoked-lens-pair-chevrolet-silverado-2014-2018/p/TLLED96/
plug and play resistors- https://undergroundlighting.com/products/7443-plug-and-play-resistor-stops-hyper-flashing-and-errors?rq=yr_2017~mk_chevrolet~md_silverado-1500-w-led-h-l~ju_rear-turn-signal
You should not need resisters.  You have factory LED already.
Rukus that’s what I thought but still flashes and I think it’s cause these lt model wire harnesses don’t have that pin in the plug in for the built in led resistor
Snowcamo yes I know and I contacted them and they don’t make ones made for oem leds and no other company makes these lights and I like these the most so I bought different wire harnesses and it works but have hyperflash
The only thing I can think of is the load resistors are the correct ones you need so that's why you're still getting hyper flash.
Sent from my SM-G955U using Tapatalk
The resistor harnesses I have have two 50w 6ohms to each bulb which as far as I’ve seen or heard is the most common
Have you considered splicing in the resistors to the harness?
That’s what I started off with I bought some resistors but before I did anything I did reading to make sure I did it right and saw I needed two resistors per bulb and at the time didn’t have enough resistors and saw these plug and play harnesses with resistors built in so I figured that would be easier
Does anyone know if you have to have the exact wattage or ohms going to the bcm  that it’s tuned to or can you have more? Cause if you can have more in that case a bigger resistor should work theoretically or not??
Have you had a chance to put the factory lights back in to make sure everything on the truck is still working correctly? You might have shorted something out with the new lights.
JomCost2014 no I have not. That’s a good idea I never thought of that. But since I changed the wire harness from the led one to the regular harness with bulbs wouldn’t it still hyperflash with regular bulbs back in or not? Or are you saying the old led harnes and lights and everything??
it probably will be PITA, but I would put it all back to stock form. Maybe one side at a time just to compare what is going on, maybe easier to track down the problem that way.
What is PITA snd if it does work stock then I’m back to where I started correct? And thanks for the help!
    jrogjr
    jrogjr
  • Who's Online   2 Members, 0 Anonymous, 365 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
