4wd conversion from electrical shift to floor shift
I had the recent pleasure of rolling my truck, the cab is smashed but that is about it.  It is a 97 silverado with the floor shifter for the 4wd.  I was wondering if anyone knows how problematic it would be for me to do a cab swap with either a 2wd or another 4wd with the push button shift?  I would like to keep my floor shift since I have never had any problems with my front differential or my transfer case, but my main question is what kind of problems am I going to run into with electrical?  Is it as simple as using the wiring from my rolled truck and that ECM and I am good to go?   Any help would be greatly appreciated.
Thank you
Awesome, thank you! I know the ECM is behind the glove box, I was planning on using my dash so that isnt much of a change of my plan, but the BCM, I cant find anything on that, is that another name for the Powertrain control module (PCM) inside the engine compartment?
