Along with having the entire truck covered with Dynamat, its sealed so tight that when I put the hvac on, your ears pop. The doors have 100% coverage on the outer shell and the inside shell. Floor, firewall, and roof completely covered. Its stupid quiet when the radio is off. Almost weird feeling. Even with the Borla ATAK exhaust.
Edited by RACERX7775
Add more content.
Forgot to say that the only reason i didnt put the tweets where you did was because i felt like there was to much seperation between the mids. This pic was before i installed the woofers.
So are your tweeters, mids, fd woofers running off one source signal (L or R) and "crossed over/tuned" 3x, or do the dash mids run the center channel mono source? What JL processor hub do you use?
The nav-tv unit takes the full range signal from the radio and sends it to the jl vxi hub. I think when you use the nav-tv unit, i think you loose fader. Then the hub distributes the full range signal to the amps. Then the amp inputs are programmed to each speaker position. So then you set crossover points, gain, and time for the specific speaker you assign to it. So, you really could have a woofer where the tweeter is. Its all settings. The amp does all the work.  Its like having a 30 band eq for each channel of the amp.
Im using all 8 channels.
2 front tweeters
2 front midranges
2 front woofers
2 rear door focal yellow components running passive
The 600/1 is running a shallow mount 12" jl sub.
Its all tuned via laptop and done wirelessly too. Check out the jl app. Called TUN.  Pronounced tune. They have a simulator to play with. It took a couple hours to set up all the speakers and hook up the rta to make sure there are no dead spots.
Check this out.
Watch "JL Audio Help Center - Parametric EQ Basics" on YouTube
https://youtu.be/IYqKFHehf9I
Damn. That's cool. I might need to get a Twk88 just to play around. Thanks for all the detail. Very nice setup you have.
Thanks. Yeah. The settings are so detailed that i dont even know what some are. You would definately need an rta to show what frequencies you have, dont have, and when they come in and out.  You really appreciate your components when they are playing how they are meant to be played.
I did my fair share of car stereo installs back in the day, some competition, some sound quality, but I would be completely lost today...The technology has come a loooong way. Awesome setup
  • 3 years later...
Hey guys, can anyone give me some tips in fixing my problem.
So I got a used 2014 silverado LT and front speaker went out along with dash speaker so I opened the dash and found 2 tweeters. Is there a specific speaker that I need to install?
Also I swapped the oem door speaker with jbl and there is no sound coming out.
    RyGuy43
    RyGuy43
  • Who's Online   6 Members, 1 Anonymous, 679 Guests (See full list)
