I have a 1999 Chevy Silverado 1500 Z71. I am planning on changing the Differential Oil, front and rear. I am getting CONSIDERABLY conflicting information on what to use to replace the oil. I want to use Lucas 75w-90 Gear Oil. Because of the vastly differing facts... I have no idea what to do in order to change the oil.a91248e516d9e8b29c230bbad9e0c874.jpg
Welcome to GMT!
What conflicting info?
The front diff you fill until it starts to come out the fill hole, which is just about 2qts.
Rear diff you fill to about an 1/8" below the fill hole and is about 2.5qts.
A 75w-90 synthetic is recommended.
AMSOIL's new squeeze pack makes diff oil changes a breeze.
CAPACITIES:
Engine, with filter..........6 quarts [1]
Cooling System, W/AC Initial Fill..........15 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Cooling System, Without AC Initial Fill..........13.9 quarts
Automatic Transmission, 4L60-E Initial Fill..........5 quarts
Automatic Transmission, Total Fill
   4 speed 4L60-E..........11.2 quarts
Manual Transmission, NV3500/MG5..........4.2 pints [2]
Differential, 11 RingGear Dana GMT 800 Rear..........8.5 pints
Differential, 8.5 RingGear AA GMT 800 Rear..........4.2 pints
Differential, 8.6 RingGear AA GMT 800 Rear..........4.2 pints
Differential, 9.5 RingGear AA GMT 800 Rear..........5.5 pints
Differential, 10.5 RingGear AA GMT 400 Rear..........6.3 pints
Differential, 11 RingGear Dana GMT 400 Rear..........8.5 pints
Differential, 8.5 RingGear AA GMT 400 Rear..........4.2 pints
Differential, 8.6 RingGear AA GMT 400 Rear..........4.2 pints
Differential, 9.5 RingGear AA GMT 400 Rear..........5.5 pints
Differential, 10.5 RingGear AA GMT 800 Rear..........6.3 pints
Differential, Front..........3.6 pints
Transfer Case, NVG 246..........4 pints
Transfer Case, NVG 261..........4.6 pints
Edited by Black02Silverado
75w90 synthetic for both the front and rear, no friction modifier for either.
When that truck was new, and up to the early 2000's, GM used to spec 80w90 conventional for the front, but had cold weather issues and issued a bulletin to switch it to 75w90 synthetic.
I, solely due to availability in my area, used the Mobil 75/90 wt synthetic oil in my rear end.
Any oil will work but you might have to go to further lengths to get a certain brand if you cannot find it locally.
  • 3 years later...
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
