I had a message on my dash stating that the inner tailgate was open.  Even though it was closed I was unable to open my main tailgate because the bcm thinks the smaller gate is opened.  Then I bring it to the dealer after 2 days not working and as soon as they push the button, it worked.  It has happened to me again since and I just keep opening and closing the inner tailgate til the main one starts responding.  It might have to do with cold winter temperatures but still cant find it yet.  Need to figure out how the computer knows that the gate it closed or open.
  • 9 months later...
  • 1 month later...
Hey, up here in Winnipeg Mb. Stupid cold here. Had the same thing happen to me. Message said top gate open but wasn’t. Took it in and they found a faulty latch on right side of top gate.
Happened to me about a week ago. I’m in Winnipeg too.
I opened the top gat, and bottom wouldn’t open. Closed top gate then bottom still wouldn’t open. My hand slipped when I closed to top gate and I’m assuming it never went up all the way and it wasn’t recognized that ur was closed but it was. It wasn’t slammed close but just softly latched.
My fix was just pushing on the top gate and everything went back to normal. Been fine since.
Hondabbq, that sounds familiar. Were u ever on trackshare?
Yes I was on TS.
What was your handle there?
I got my 19 in October. Been flawless for the most part. Minor issue with park assist sensor after washing, but that’s it.
Seems like the update issues are now fixed so I’ll be booking it in to get those rectified soon.
  • 2 years later...
I apologize if someone else on this topic has already commented about a solution. I believe my friend and I have found the problem due to trial and error after we loaded a snowblower onto my truck and could not lower the tailgate. We believe the problem lies within the inner tailgate which is the smaller section of the tailgate on top that is able to fall down but the main gate will not. The inner tailgate has latch points on the right and on the left. if you take a hairdryer or heat gun and heat up those two areas you will have a fix to your problem. After being in cold temperature with snow and ice I believe what is happening is that condensation or moisture gets in those areas around the sensor and either refreezes or frosts over causing an error in the computer thinking that the tailgate is open.  Four times now we have tried the solution and it works like a charm every time. I bet you will see the correlation between dry days with no snow or ice and days that have it causing the error. I hope this helps everyone understand what’s going on or find a way to explain it to a technician.
    liddlera
    liddlera
  • Who's Online   6 Members, 1 Anonymous, 391 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
