Update - Leaf Spring Squeaking and Clunking
It appears GM may have come up with a solution. I was told it’s “not on the books yet” but seems to be a beefed up version of the bike tube trick. If you’re still dealing with this issue you may want to check it out. I’ll update in a while with how well it’s working.
I bet soft Teflon is used between the problem leaf springs
Sent from above
