Is there a catch can and a breather setup?
Very nice and the dual open port to intake will keep the crank pressure down just keep a eye on it. Can such oil fumes into the intake. That's why the big power vehicles use a 5 port tank with breathers. But i wouldn't worry his minute about it.
How often should I check the catch can? Don’t know much about the setup as it is. Thanks for your help
That's so rad!! $6500 for the whipple plus all your add ons I'm sure your over 8k I hope it runs like a beast!
Thanks! Parts alone are past 8500 so far not including labor. My wife doesn’t know that much yet [emoji23]
  • Haha 1
Just now, Denali34 said:
Thanks! Parts alone are past 8500 so far not including labor. My wife doesn’t know that much yet emoji23.png
Brother I am juiced for you! A whipple on a clean ass lifted truck, thats the stuff dreams are made of! haha
Odd part is in was just thinking that today. I empty mine daily. But that is only bc the super cold weather and the aluminum catch can and the quick heat of the motor cause half the can to fill with condensation. If this continues this summer I will install a auto drain. And if I was you at say 3000miles remove intake and look at throttle body blade and inside intake tube. Wipe it and see how.much oil is making it that way.
Thanks man. I love your truck as well. I’ve been following your build since last year. Do you own a powder coating shop? That white and bronze is [emoji91].
2 hours ago, Denali34 said:
Thanks man. I love your truck as well. I’ve been following your build since last year. Do you own a powder coating shop? That white and bronze is emoji91.png.
Thanks brother! I do not but my friend Kevin does and they are pretty good at what they do. Thank again and are you on IG because I know you’re going to post videos and I got to check it out.
Yes sir. I just started following you. Denali_34 is my user
Boom!
  • 4 weeks later...
On 3/18/2019 at 5:20 PM, Denali34 said:
Hello all. Well the time is finally here. Dropped off my truck at Vengeance Racing to get my 2.9L Whipple put on. They’re installing the Supercharger, Kooks Headers, Taylor wires, NGK Plugs, Catch Can, 180 degree Thermostat, Smaller pulley and custom HP tune. Expecting 520+ WHP.
Thanks for following along.
Nice!   I google VR and they aren't far from me.   I am not interested in a Whipple for my truck, but they do have a Corvette package I am interested in.   Thanks!
They are one of the top tuners in the nation. I highly recommend them.
Where are they located?  I'm finding several "Vengeance Racing" companies out there.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
