So I noticed my AT4 has two valves one before the muffler and one after the muffler. Has anybody clamped them open as it was done in the previous gen?
Just looking into getting a bit more sound. I went under the truck and held one open but didnt notice much difference. Today I stumbled upon a youtube video and noticed their was two valves. I guess I can give it a go this weekend; basically just wondering if its been done and if you are happy with the results.
Yes, i removed both valves. They each have a 1.25" restriction. The aftermarket GM (Borla) exhaust eliminates the valves. I cut both mine off and installed a Magnaflow 12909 and gave it the sound and performance it should have.  attached is a picture of the valve in the open position.
Interesting to know. I was under the impression that the halve would open fully.
If that half round section wasn't part of the valve, it would be fine, however, i'm sure it's part of the reason its sounds the way it does.
This is interesting. I wonder if the back pressure somehow creates more horse power?
Back pressure assists with the cats working properly but does not help performance
Sent from my SM-G975U1 using Tapatalk
I found this which would be easy to install but the price is just too exaggerated I think; plus the valves would still remain in place as it does not state that it's long enough to cut them off. Perhaps I am wrong.
Edited by asalinasz39
The GM exhaust kit does away with the flappers, there is no reason to keep them. It's cheaper and more effective to just cut the flappers off and install a Magnaflow or similar muffler and be done. A muffler shop can do it all in less than an hour. It's easy stuff for them.
The GM aftermarket cat back system does not use the flapper valves. That tells me they don't aid in horsepower, rather they restrict it.
So I am looking at this muffler Borla XR-1 Racing Mufflers 40085 or the carven r which I loved on my 2016.  WHen they put in aftermarket muffler what do I tell muffler shop to do eliminate the flapper valves or do they get eliminated when you put in aftermarket exhaust.  SOrry if this is a stupid question just want to give shop the right directions.
Totally makes sense to me guys! Thanks! I will temporary clamp the valves open and see what it sounds like until I have a chance to head out to the muffler shop and cut them off followed by a replacement muffler.
You should tell them to eliminate them just to make sure they do and get your full performance and sound desired.
That won't help much.; They have a 1.25" restriction (as per the photo above) when open. Best to cut them off.
Not a stupid question at all. When they install the aftermarket muffler they can either cut off the valve and hand it to you so it can be reinstalled later if need be, or they can leave it. They are located behind and in front of the OE muffler (if you have a 6.2). I doubt there would be much of a performance difference if you leave them, however it will be quieter due to the restriction. I say cut them off, weld on the new muffler, give it a chance to break in and see if you like it. If it's too much, they can weld one back in. If it's still too much, weld in the other one. I would leave the resonators, they are straight through and don't offer any performance advantage if you cut them off.
So i was under the impression that my AT4 had 2 valves however looking under the truck mine only has 1. I had seend a youtube video earlier with a 6.2 At4 and that must of thrown me off. My 5.3 only has 1 valve.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,793 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
