Headlight question
Hi everyone, new guy here. I have a 2017 LTZ and I like all the chrome on the truck other than the chrome grille insert. I can get a kit to make that part of it black but there is a bit of chrome underneath the lens that has chrome on it. Is there a way to get in there safely and remove that chrome either by painting it or some other method? In other words I prefer the LT look grille and headlights better.
15 minutes ago, SirenRed16 said:
Are you talking about the chrome inside of the headlight?
Sent from my SM-G955U using Tapatalk
Yes sir I am
You can have a shop open up the headlights and paint the chrome which there is always a risk or we can trade headlights. I wouldn't mind LTZ headlights lol
Do you have LED projectors? I don't wanna give those up.
Sadly no. LTZ and high country get LEDs, LTs get HIDs
Well that's a bummer, that would have been a good idea.
I wonder if its possible for us to keep our bulbs, just trade housings.
I have no idea if that's possible, hopefully someone will chime in on that. I'm a very mechanically inclined person so I'm not afraid of modding stuff if it's possible.
Nope. Totally different. Projectors are only made to fit a certain bulb. I’m pretty sure the LTZ has the led signal lights while the LT only had halogen signals too. The BCM is programmed to read different voltages also. Only way is to open the lights up and paint them.
Have you or anyone opened these up? I know the Ram guys gotta bake them I think to get them apart.
Oh yeah, lots of guys have. I did my 14’s. Easy. Pgamboa just had his opened and had someone add the Klearz on his ‘16. You have to bake to open. Permaseal, but it’s not terrible to open. Just use heat and patience.
Nice! How about sealing them back up? Easy?
I used retro rubber from theretrofitsource.com. It’s a butyl rubber rope sealant. Zero issues for 3 years. I also went over the seal with some rtv for added protection.
Awesome! Thank you! I’ll be able to get the look I’m goin for and keep my LEDs
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
