I'm having same issues just purchased 2020 1500 lt Duramax. Pulling a 2009 jayco 26bh
 completely bottoms out the suspension with the truck empty. Bought a 10000lb weight distribution hitch and having exact same issues. Remeasured everything 3 times tried setting hitch up for Max weight 1000lb tongue and it still can't compensate for the excessive sag. My 2016 1500 didn't have any issues at all nor the newer f150 the previous camper owner was using. I really really like this truck but there's definitely something wrong with the rear suspension.
2009 Jay Flight Floorplan 26BH
Weights
Unloaded Vehicle Weight (lbs.) 4,445
Dry Hitch Weight (lbs.) 580
Gross Vehicle Weight Rating (lbs.) 7,500
Cargo Carrying Capacity (lbs.) 3,055
Just got done at the scales 800# tongue weight picked up some airbags to take out most of the squat going to use equalizer to finish the job now that I know I'm under weight limits must be really soft springs or they forgot to add a leaf lol
I tow about 8500# boat with my 6.2 AT4 on stock suspension. I added sumosprings blue without the spacer and fixed the issue without ride quality change unloaded and cheaper/less complex than bags. I put them on yesterday in about 20 minutes and completed a 300mile tow last night. wasn't blinding oncoming traffic like previously. nice and level. cheers.
Tongue weight on my trailer is over 800, and with the WD hitch, I'm level.  That also includes the bed filled with two large ice chests, bbq, outdoor oven, propane tank, sat dish, pop-up and chairs.
I have the exact same issue with my 2019 AT4 6.2 w/10speed, 750 lbs on the tongue and it dropped almost 3”. I initially thought maybe it was the hitch or equalizer bars not carrying the weight properly. I adjusted the hitch according to manufactures recommendations with proper height adjustment and that was not the problem for sure.
I installed some super springs but they didn’t help as much as I wished they would’ve. Squat went from 3” to approximately 2-1/2”
Also with super springs they don’t fit quite right with the suspension on the right side, I have rub marks on the muffler and the frame (from the bolts/bracketing on the super springs) Contacted super springs service department and then they had me take pics and send them to the engineering department and they suggested I move them forward 2-3” but they will just settle out back to centre over time.
GMC has dropped the ball on the AT4 suspension big time!!
What is the payload rating on the door for the people having issues with sag? I’ve seen ranges from 1000-1900 which all still technically allow for 930lbs on the hitch, but I’m sure would handle the hitch weight differently based on the payload.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
