hard starting in 2000 5.3 L
Hey everyone -
I've done enough reading and talked to enough people to think that my hard starting is due to the same fuel pressure regulator problem that many people have been having. It starts fine for the first time during the day, then starts hard after that. But runs fine once it starts.
I located the regualtor and want to check the vacuum hose to see if fuel is leaking past, but don't know which is the vacuum hose. The pic below is what I think is the regulator. You're looking at the driver side of the engine, rear of the truck is to the right. Which hose is the one to check? And do I need a tool to bleed off the pressure in the system before changing the regulator? Much obliged!
~Mike :eek:
I just had to replace mine a week ago. You can buy though the dealer/AC Delco or buy a aftermarket part. The fuel pressure regulator is part with the clip on it. The AC Delco part came with a new clip. The clip is easy to take off just use a scewdriver to take it off. The fuel pressure regulator part will come off after the clip is removed. Sometimes one of the 0-rings get stuck it the housing. The new fuel pressure regulator should be easy to put in.... Dont force it.
Buy a service book, Its detailed to get the job done.
Good luck
I forgot....
The vacuum hose is the thin one just right of your arrow. If you pull up the vacuum hose and see gas coming out that means you need a new pressure regulator.
One more thing...
when you replace the pressure regulator... let the truck sit for a hour because if you dont gas will shot out the pressure regulator opening. Maybe you shoud bleed off the pressure anyhow.....
I replaced mine yesterday. Piece of cake. There is a shrader valve on the fuel line on the left side of the intake manifold that you can use to release fuel line pressure. Put a rag under the valve and under the regulator or gas will spay on and under the intake manifold. The GM part number is 17113678.
I want to thank all who have posted on this topic. You saved me lots of $$$. Eventhough I could have saved even more if I had bought at GMpartsdirect.com and waited for the part to be delivered. I'm pulling my 5th wheel this weekend and didn't want any problems.
    HWN808
    HWN808
  • Who's Online   3 Members, 2 Anonymous, 966 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
