A/c condenser replacement
You should have it properly recovered and recharged. Take it to a shop and have them recover whats left, go home and change it yourself then have them pull vacuum and charge it correctly.
Yeah use a shop to do it so they can vacuum it down. Here is a video on how to do it though. It also Has the amount of Freon you need in the video.
The sticker on the radiator cover is in kg, just type that into google and it can convert it to oz for you. You can definitely do it all yourself,  pulling vacuum and charging too. Only issue is recovering anything left in there now, but Im sure if you call around you can get some little shop to do that cheap enough.
