No heat=change antifreeze
My parents '96 Jimmy and '97 Sonoma have terrible heat. The service manager at the local GMC dealer told my dad to change his coolant from Dex-cool to regular 50/50 blend of reg. green antifreeze. Does this indeed fix the problem?? ANy thoughts would be appreciated.
:rolleyes: If the anti-freeze has turned brown it will make a big difference,the system will also have to be flushed and heater core back flushed.
Nooooooo, do NOT do that! :thumbs:
The two WILL MIX and make your problem even worse. Just a simple back flush at a full radiator shop and a refill with dexcool will solve your problems. My ZR2 had the same problem this past winter. :rolleyes:
Ya that's a load of crap!Mixing Dex and green = serious damage to your cooling system because the last time I checked they break each other down instead meshing.
Do a total cooling system flush,change the thermostat and go back with a good anti freeze like Prestone or something.
Sounds Like some Very Bad Advise! :cheers:
My father had to take his 1996 s10 Blazer back to GM and they flushed it under warranty. The pink stuff broke down prematurely. :rolleyes:
There are plenty of good anti-freeze brands with Dex-Coll in them. I used Havoline Dex-Cool in mine after the motor swap. It's been fine. :thumbs:
The 1997 Blazer I have has had no troubles with the anti-freeze or heating. :thumbs:
Can someone explain how to backflush? I have just started doing the maintenance work so I'm still relatively new to doing it and I did want to do a coolant flush sometime soon. I was also planning on switching over to regular coolant instead of dex-cool.
