On 4/28/2019 at 2:00 PM, destrada127 said:
Wow! $4k for a little sound and better flow just to be choked back down by cats. I'd rather spend that plus 2 more on a supercharger
Sent from my SM-G975U1 using Tapatalk
Long tubes bypass the factory cats , normally you run them catless and tune out the sensors, they offer Y pipe with cats but it defeats the purpose a bit.
On 8/30/2020 at 11:47 AM, calgator73 said:
Has anyone added the kooks headers with ultra green y-pipe and not tuned?  love to see the dyno results.
You would still Likely get a cel and need a tune , the long tube headers are much longer than stock , once adding the new Y pipe the cats are much further back than stock configuration, requiring O2 extensions , cats use heat To function and the further back Cats are the more likely they wont function efficient enough.
I posted this after I heard back from Kooks...I'm hitting them back up for a dyno sheet today.
9 hours ago, Chips said:
Ive been kicking the tires on these once they are stock I may pull the trigger.
https://pertronixbrands.com/products/jba-performance-exhaust-1850s-5-1-5-8-header-shorty-stainless-steel-2019-2020-chevy-gmc-1500-5-3-6-2l-l82-l84-l87?variant=31797186232356
They bolt up to the factory Y pipe and cats.
I don't know how much of an advantage running shorties through the factory cats would provide.  Easy way to avoid a CEL though.
It changes the exhaust note a fair bit, deeper meaner sound.
Also
They are using the same term "gains" as kooks.  Really need to see the dyno.  Having a difficult time finding anyone who has run any of this without a tune.
Afe has shorties for these trucks and Dyno sheets posted. long tube require a tune no matter what. But ive seen a few shortys on the silverado 1500 without a tune.
Note “Gains” vs “peak”.
Gains are taking from a dyno run where the highest delta is. Peak is taken from where the peak power is generated.
If at 4000 RPM the difference is 15 HP between Headers and no headers but one peaks at 290 and the other 280. The gains are 15 HP but the peak Increase is 10hp increase.
See attached Dyno sheet for comparison of stock vs shorty headers.
  • Thanks 1
Thanks for posting this.  I have always been of the same thought.  Shorties/mids no tune required but long tubes definitely.  Thought it had more to do with the cats being so far back and getting cold or something.  Looks like my truck will be done today and they extended my warranty for the powertrain.  This will be put off for a bit.
This whole needing to tune on headers isn't completely accurate. I ran my full stainless works setup with defoulers and worked fine. BUT. A tune will greatly aid and while 1400 for unlocked ecm plus headers seems a little steep you gotta pay to play.
Now while I run my procharged setup on my 2020 5.3. I am waiting on seeing if someone makes a 2 inch primary setup for when the LT1 416ci goes in when i have the P1 swapped to my F1 blower. She's gonna need it.
But for all intensive purposes. There are far more people running headers with no tune and no cell than most really know about.
Edited by IrritableVet
Updated
2 hours ago, Gangly said:
You can run long tubes without a tune, but you benefit the most with a tune.
You can but the tune is to tune out the cel, sure some run defoulers but they dont always work .
I haven't seen any Long Tube header systems throw a CEL unless they removed the cats entirely as opposed to simply moving them downstream in conjunction with 02 extensions, or installing high flow cats.
That sure is the theory is to see if they will do it. As most header design gets better so do the abilities to defeat the CEL. Most new style Defoulers come with flow inserts to thwart that issue. Not the right way, but a way none the less.
most the green systems are pretty good about it.
Oh I just assume anyone running long tubes are not using cats . And if they are they arent factory cats which also tend to throw a code.
Im interested in defoulers with flow inserts just to further my knowledge. Can you link me .
Defouler
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 394 Guests (See full list)
