Seems like on my 2020 Sierra 2500HD awhile back when any of my three trailers were plugged in and the truck was turned off the trailer lights would only flash every 30 seconds or so? Lately it's almost a constant flicker with any of the trailers.
I get the flashing lights for security, but mine flicker irregularly and every second or two, almost like morse code. A few posts i read said they were getting a flash every 10 seconds.
  • 8 months later...
On 6/26/2023 at 9:21 AM, MrMagloo said:
Same here.  Appears to be the Trailer Connector security feature.
I dont like the flickering but this says we can at least set it to one blink every 42 seconds instead of the constant light show!
https://gm-techlink.com/?p=14165
  • 5 months later...
On 5/2/2019 at 8:14 AM, Rsktm300xcw said:
That link is very informative and would have been very helpful to me about a month ago. I through a ton of trial and error figured out that my trailer lights need to have just the right amount of load for everything to work correctly. A little tip, if you have LED lights and are seeing error being detected by your trailer light test adding a resistor to the circuit fixed my brake light problem. On my running lights circuit my trailer had 17 incandescent lights and they would all turn on for 1 second and then turn off every time I tried them. The trailer test showed a running light problem. I swapped all 17 out for LEDs to reduce the load and that seems to have solved my problem. So it is very important to reach the right  balance for the trailer light control module to see enough load to know that the light is working but not to overload so the module shuts the circuit off. Can be tricky. There is also an update out to "reflash" the module. I dont remember the number but it listed near the end of the cold weather electrical problem thread. My local dealer did the update as well. So far dont seem to have problems. Waiting for first long trip with the trailer to see if it is all solved.
What circut did you add the resistor, and what resistor rating did you use? THanks!
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
