Power steering
Long time lurker first time posting (finally made an account). I done screwed up today. I put in a 2” leveling kit and following directions got me into trouble. The directions said to remove power steering plugs and well 2 tabs broke. I used a big zip tie and glued the connector back seems to be okay. I did see some people have had this issue and wasn’t sure if anyone had a better solution? I know I can order the harness but the big connector in the middle broke on the rack side and I don’t want to pay 1000+ for a new rack due to a broken tab.  Wish I just left the steering connected like my gut was telling me to. ?
So you're saying the locking tabs that hold your connectors in place broke?
It's not a connection that you will frequently disconnect. I would plug them back in and join the two halves of the connection with a bead of 3M DP420. It's aerospace grade epoxy.
If you need to remove it, you can heat it up (soldering iron in close proximity) and peel it off like a booger. Comes off cleanly unlike glues and RTV.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Yes. The locking tabs broke. One broke on the harness side and the other on the rack side. I didn’t even notice until I put it back together. That’s a good idea, I used super glue but I wasn’t sure if it would hold well enough.
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
