On 2/17/2020 at 2:34 PM, splatmatt said:
Well it has been around 500 miles since EBCM firmware was applied and the dealer performed a history wipe.
One thing I noticed is MPG is about 1.5mpg better and the voltmeter on the dash is always riding above ~14.4V. After the update it now seems to behave more typical to the GM regulated voltage control system and zero codes including all of the modules.
What EBCM firmware update was applied?
does anyone have the bulletin number?
Edited by Elpresidente
Went to the recall site.  My VIN does not flag this recall.
as well after reading the bulletin.  I do not have the ABS or ESC lights on, on the dash console.  I know because the first time this happened took a picture of the dash console and looked at it now
have never used the app to start.
the last two times did not wait the five minutes to start the car.
not sure the recall applies to all the U code MIL errors.
if anyone else learns anything applicable.  Please opt in.  I know there are other people having this.
I never used the app to remote start either as I do not have a remote start.
I posted the recurring codes I was having earlier in this thread and you quoted me and asked what was the document that referenced my issue with these codes.
Have you scanned the codes yourself? You will need a code scanner that is capable of reading the modules.  I use the BlueDriver scan tool https://www.bluedriver.com/products/bluedriver-scan-tool
Additionally, your best start is probably to follow chain of command at your dealership.  If you have hit a dead end with the service advisor, talk to the service manger, and then call GM for additional support or try another dealership.
One thing I learned is if a module is updated, other modules may need to be updated as well so they can properly communicate with each other; otherwise and error may occur.
Also, find out how long your truck sat on the lot.  If it sat for a long period of time and the battery was not maintained the main computer may need to be re-flashed and the a complete history wipe of the codes may need to be performed.
Pulled the codes with two different readers, on different occasions.  Was at home once and at Dads another time so used his reader another time.
Truck had only been on the lot for days.
Yesterday finally got the dealership after a couple visits to address; probably what happened is the internal engineer case approved the work.  I know they changed multiple parts and reprogrammed.
when I pickup will update the outcome for the community.
  • 3 weeks later...
On 2/10/2020 at 5:09 PM, splatmatt said:
I've been seeing these codes show up on my Bluedriver OBD II code reader even after today's most recent recall that refreshed the EBCM.
If anyone has a fix for this I would appreciate the info - dealer is clueless in the matter.
Here is the summary:
****Update
well, dealer said codes were history codes. Flashed ECM and reflashed EBCM for second time under latest recall. Performed a “complete history wipe” whatever that means - not sure how that is different from clearing codes. But I had to go back this morning for a B1517 as they left some connections loose.
Now I have driven 60 miles (since this morning) and 0 codes and transmission feels very smooth. Fingers crossed.
I'm having this exact same problem since purchase 4 weeks ago. Been  back to dealer twice. I'll be back as soon as this virus thing settles down.
My 19 HC came up with these 4 codes talked about here today also. Check engine light went off after 2 restarts. Have had truck for over a year and 23k miles, recalls all been preformed.
just noticed window leak yesterday also
u0101
u0100
u0146
p25A2
Edited by Kevin0311
Kevin0311 we have the same issue.  Told everyone would come back and support.  Have been in the dealership three times.  First and last time they just cleared the codes.  Second time they replaced the electronic brake module.  As well they flashed it with the latest as of February software update.
during the second service they could not get the codes to go away.  They did a software reset procedure multiple times and could not get the software to upload eventually they got lucky and got the upload to the EBCM to work.  Although even by a brake bleed and physical reset they could not get the codes to go away so they just cleared them out of the computer.
Disappointed with the lack of fundamental knowledge the service writer and techs had about how to deal with a software issue.  They think that a code a OBD2 code is a match for a solution .  It’s a match for a system or component having a problem but it’s not a match for an excat matching root cause.  They fundamentally did not grasp that different software problems could bring up the same obd2 code; They had no idea what a data debug or dump was that they could upload to the GM engineers.
Typical non logic or methodical troubleshooting; just random attempts at anything.  If something clears a code or hides the code it that is good enough.  Still a little baffled that GM tech training does not include what most junior high AP Computer students know about how to start troubleshooting software issues.
Supposedly over a month ago (about feb 20ish) a new software fix would be ready in a month and they would call me back.  Have not heard back yet.  Had the codes another time when my wife was driving the truck had her confirm as have been keeping my obd2 reader in the truck.
will put my service work order here and my GM case number.
Anyway we can get everyone to post their case numbers with GM/Chevy engineers.  The techs at every dealership will have called into GM and made a case which has a number.  If we all share the case numbers here.  And share this thread with the dealership to give back to the engineers they can cross reference all the cases.  If a fix is not in the works this will prove to the engineers and product team multiple people are having the issue and will get it prioritized.
Just want to chime in. 20 Sierra AT4, 3.0, 500miles.
Just got P25A2, U0100, U0101, U0146, with a CEL. Going to go see the Chevy dealer tomorrow as the nearest GMC dealer is almost an hour away.
Has anyone truly gotten this cleared up? Any insight to encourage the techs to look in the right direction instead of just random guessing?
2 hours ago, tbarn said:
What might that "right direction" be?
I suppose that's the real question, huh? Does anyone know what the "answer" is? Has anyone heard back from GM with a real solution?
Add me to the club. I have a 2019 Silverado WT, double cab, 4x4.  All recalls up to date. I warmed up the truck this morning since it was cold outside. After about 10 minutes, I got back in the truck to find the check engine light on.  Hooked up the scanner and found codes U0146, U0100, U0101, and P25A2.  I used the scanner to clear the codes, and the check engine light went away, and all codes cleared.  So far they haven’t returned, but I’ve only driven the truck about 20 miles since then. Has anyone figured out what the dealer is doing to remedy this? Just curious, because I have that funny feeling that it’s going to come back and I’m going to end up at the dealership. And just FYI, I have never told anything with this truck before. I also had the brake module recall performed about a month ago. Never had any performance issues out of the truck. Truck ran fine, shifted fine, and break fine the entire time the MIL light was on
Edited by Brizzo Jenkins
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,210 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
