Procharger kit while running a cam???
Is it possible to run a cam while running a procharger kit? What would I run if it is possible and what type of problems would I need to avoid? Also, would I need to run other mods like new headers or something? Anything helps thank you
Easily done, just need parts that complement each other. If your doing a cam I would replace the lifters, new correct length pushrods and get the heads milled flat at the minimum. Then headers would really open up the flow.
That's just me. You can for sure throw a cam in without taking off the heads but it potentially can throw off your pushrods length depending on the cam. Spend time with emailing different cam manufacturers to see what they recommend. I love working with Texas speed.
Depending on the size cam and tune, a little more loose torque converter will help with the drive-ability of the truck if you put a decent size cam in it. However, this is not  a "necessity" but would help. Just like headers are not necessary but will compliment the cam and especially the procharger.
Thanks for the input guys. I’m looking to get a stage 2 Texas Speed cam first and later down the road throwing in a procharger. Any recommendations for lifter upgrades? I was gonna use the ones that came with the Texas Speed AFM Delete kit
