Wiring is NOT the problem. You need to take it to the Chevy Dealer and get an update to the Trailer Lighting controller. I had this issue. 12V was not present on the running lights for the trailer. Stop lights and turn signals did work however. I have a 2020 1500 Siverado and they had to swap the controller. Here is the bulletin.
NHTSA Bulletin 20-NA-198
https://static.nhtsa.gov/odi/tsbs/2020/MC-10181721-9999.pdf
2019 Model Year vehicles, equipped with U1D, use the K68 Trailer Lighting Control Module to control all trailer lighting through pulse width modulated (PWM) voltage. The Trailer Lamp Control Module has a current handling capability on the running lamp circuit of about 9 amps. On a trailer with a large number of incandescent lights, in-rush current can exceed 20 amps before it settles back to around 8-9 amps. During this inrush or "marriage" current period, the Trailer Lamp Control Module sees the current as an "overload" and goes into protection mode.
  • 5 months later...
On 11/23/2019 at 7:48 AM, Rsktm300xcw said:
Has anyone with these problems tried the trailer light module reprogram I mentioned earlier. It helped my truck a lot. I believe that it widens the acceptable amp draw of the trailer lights substantially. My running lights were drawing too much so it would shut down so I swapped all trailer lights to led. Then my brake a d signal lights were not drawing enough so it shut down so I added the resistors. Now after reprogram and new lights everything works as it should. Also eliminated the trailer disconnected message that used to show up frequently. A combination of new lights with the proper amperage draw plus the refresh has almost completely eliminated these problems.
Where did you put the resistors? Im trying to fix my 2022 now. Lights all work durring the day when the running lights are off. As soon as I turn on my trucks headlights (making the running lights come one) the turn signals stop working immediatly, so it's deffinitly a power delivery issue... What does the dealer reprogram and where do I put the resestors?
  • 1 month later...
This thread was very helpful, wanted to contribute something back:
Spoiler:  replaced Fuse 74 TIM, fixed our issues.
2019 Sierra SLT X31 Texas Edition, just bought it used about a week ago.  First time towing our small utility trailer, had trailer lights when we left home Friday.  Two days later (today), no trailer lights at all.  Even with no trailer connected, the monitoring system was showing trailer connected, and flagging an issue with Left and Right turn lights.  Also at this time, the truck turn signals were "fast blinking" like an old school flasher going bad.  We left the trailer at the camp and got on the road. This is when we also noticed the Fuel "distance to empty" was not updating, just frozen at like 283 miles even after driving 20 miles or so.  Long story long, I head read this entire thread by the time we hit the Dairy Queen (I'm riding shotgun, its my sons truck) and I hopped out and pulled Fuse #74, sure nuff, busted.  Replaced it with a spare and all symptoms resolved with the trailer monitoring system and fuel DTE updated immediately. Hope this helps someone else.
  • 2 months later...
I have same issue with a 2020 Silverado 2500 HD. Really sucks can’t tow anything till issue is fixed all fuses are good Chevy should address this issue.
  • 1 month later...
On 6/6/2021 at 12:59 PM, Backyard Hack said:
I believe I stumbled on the solution. I had the same issue with my 2020 Sierra. I could hook my trailer to other vehicles and the lights worked. Hook it to my Sierra, and nothing. A seven pin tester indicated no power to the receptacle (although I could see very very faint flashing of some lights on the tester). I checked every fuse and all were good. Stumped, I looked at forums for ideas... nothing worked. Then my 5 year old daughter was "helping me" and inquired about the trailer hitch icon when I placed the truck in reverse - trying to be patient, I showed her how it magnified the hitch (I don't usually use this feature). When I put the truck in park, the park brake engaged and I suddenly had all my trailering lights. The display also inquired about which trailer was connected.
I'm thinking it is some sort of technical setting. Back to your trailer normally and before hooking the trailer and lights use the hitch magnification feature. Hook everything up, you should now have power to the trailering plug. Ever since I started using the magnification feature, I have power to the receptacle. If I forget to use the magnification feature the lights don't work on some of my trailers, but do on others??? Simply use the magnification feature and the lights work on every trailer... go figure???!!!
On 3/3/2025 at 2:58 PM, Allan Williams said:
tried the magnified hitch trick and it worked but sadly only once. can't seem to replicate what I did. This is my 5th suburban and likely my last GM product
We want you to love your Suburban again, Allan. We want to learn more, and ask that you email us at [email protected]. Please share your full VIN, some further details regarding your concerns, and the name of your preferred dealership. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
