It crossed my mind that I may have too much draw on my running lights circuit because of the I sec flash then they go out, like the truck is sensing a large draw and shutting down. I have a lot of lights 19 small lights plus 2 tail lights. most forums talk about too little draw because of led's but maybe I have too much. Maybe I'll try disconnecting some lights if that works I'll go to dealer for reprogram. maybe I can mix led's although I think its not recommended. thanks for all the help.
It crossed my mine that I might have too much draw because lights flash on for a sec. like the truck senses the draw and shuts off power. maybe I'll try disconnecting some lights. If that works I'll bring to dealer for module reprogram. thanks for all the help.
I had the same issue on both 4 and 7 pin connectors. I tried two trailers, a set of tow lights and put a meter on it but I was getting no juice.  Connectors were good and fuses were good so I took it in to the dealer.  Four hours later, I had a "new harness" as apparently some wiring harness that that fed power to the trailer lights had a grounding issue.  A PITA, but all fixed now.
my problem is different apparently in new gmc's too little draw from led lights  or too much from incandescent causes truck computer to not send power to tail light connection. my trailer has about 20 running lights, I disconnected about 10 connected truck and the rest lit up, so I plugged in one at a time and they lit until I got to 16 then they all went off. tried switching different lights in case it was I short but would light at 16 but no more no matter where they were. ordered some led's to substitute about 10 incandescents, hoping they draw soo little it will work. hope they will work together.
rsktm300xcw you were right. I tried disconnecting 10 running lights and the rest lit up. I plugged in one at a time and they lite until I had 4 left then they all went out, unplugged  different lights will work with any 4 unplugged so I ordered some led's to substitute incandescents hope this will work.
I believe the reprogram of the trailer light module widens the acceptable amperage draw and may help with this problem. Not positive though. I know that after changing all running lights to led problem was solved. Then I changed brake / tail lights to led problems arose due to too little draw. I added the resistors and all working at this time. Reprogram also helped with trailer disconnected issue.
2020 Chevy 2500HD at the dealer for none of my trailer lights working. Brake controller works fine.
I just tested amp draw from RV trailer at right around 4amps.
13-192 marker lights
1- license plate light
2- 3457 brake stop tail lights
seems this should be more than under any programming safety limit. Should know shortly what they come up with.
worked fine with three trailers with LED lights so I can’t imagine the new trucks only allow new led lights that draw less amps.
Edited by Christopher Murphy
  • 4 months later...
Has anyone solved the problem with running lights not working but all other trailer lights work dealership and trailer repair can’t solve. Trailer lights work fine when connected to other trucks. My truck is a 2019 Silverado. Please help. Email at [email protected]
or text me 859-361-9531. I need my trailer for work and it’s killing me. Thank you
I had the same problem with my 2018 Silverado. I hooked up my trailer lights to my wife’s car and they worked fine, when I plug them into my truck they wouldn’t work and even blew three fuses under the hood. I finally figured out that a ground wire needs to be connected to the each light fixture at the back of the trailer.  I just spliced into the white wire at the plug and then ran two wires down both sides of the trailer, then connected to the nuts that hold the lights onto the trailer.
Once I did that, they worked! Hope this helps!
I bought my Denali in December and it's been in service about 70 days. Service manager called me Friday to say it's fixed. I went to pick it up and he said not fixed because nothing wrong. They had it a month and did nothing at all. I plugged in a trailer light tester and showed him that non of the lights were working. He said, so what. Because of the virus,  engineering said it's a non issue and not fixable. Wtf? Now my 5 month old truck with 1500 miles on it is home and still cannot pull a trailer because there are no lights. Thanks GMC for the greasy$70k truck
 Jeff please try this,  connect truck with lights on (parks) and let hooked up for five minutes.....it seems like it takes a  minute for the truck to recognize trailer.....mine was the same way and now everthing is great! It even blinks trailer lights( 1 flash per +- 45seconds) because of theft feature.....nothing to lose!
I escalated this to gm in February. They began the buy back process but because the idiot service manager told them that nothing was wrong, it was closed. Now I've escalated again and filed for lemon law protection.
I keep getting errors and 'off' notifications on the dash. Things like Lane keeping off, parking aid off, cross traffic off and others. They are totally random. Sometimes 40 minutes until the first warning and sometimes 40 seconds until the first warning.The warning usually goes away after a minute or so. Who knows how many safety systems are offline. $70k truck and I can't even hook up a trailer or trust the safety systems.
Did I mention that the truck was damaged and repaired {new front fender} before I bought it and this was never disclosed! What a dealership.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,477 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
