Fox 2.5 Coilover's with DSC - Settings
dab86
Hi there,
I decided to order a BDS 4 inch suspension lift that comes with the Fox 2.5 coilover DSC's. Can anyone confirm that the softest setting (Turned all the way to the left for both low speed and high speed compression) is the same dampering the non DSC coilovers are at? What settings do you guys run for smooth everyday driving?
Thanks!
Typically, a non adjustable coilover will be valved in the "middle" - with an adjuster you have the option to soften, or firm up the shock depending on driving conditions.
I confirmed with Fox....Both knobs all the way soft is equivalent to the non adjustable Shocks. So the Shocks can only be adjusted firmer and not softer than the normal non DSC Fox Shocks.
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 859 Guests (See full list)
