Fixed pedal to pedal adjustment feature
Have anyone try (or know an answer of) upgrading the fixed pedal (Throttle and break) on 2015-2019 Tahoe/Suburban LS and Yukon/Yukon XL SLE to add the feature of auto pedal adjustment level?
Is it only the motor to add with the knob and electric wires, or it may include BCM?
I’ll look into it. Can you send me a pick of the switches you have just to the left of the cluster?
Thank you, it looks like that
Thanks for the pick. Here’s the switch you’ll need. There may be one without lane departure, but I haven’t found it.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232648849366
Thank you for the link.
My problem is: I think I have to buy the motor that changes the position of the pedals, the switch that you provide, and some electrical connections to the fuse box.
But, do I need a BCM programming as well?
I’m looking over the wiring. Based on what I’m seeing, I don’t think BCM programming is needed for those without seat memory. There’s some wires I’m going to ask you to look for. I’ll post instructions later today.
Great, thank
Do you think it is doable?
I was trying to find out and I find, as you just said, with RPO (HF4) without A45 memory seat as you mentioned.
BCM is used to cut-out voltage when gear is not in park, so can I override?
My understanding is, I need:
- Switch next to the steering wheel.
- Motor.
- Relay/fuse at the Left fuse box.
One more thing, do you think is it safe? Do I need adjustment/calibration to pedal position throttle and break?
Thanks, and sorry for all that questions [emoji1319]
Great, thank
- Motor.
In short, yes, it’s doable. I believe the park position switch is still present even without adjustable pedals. See if the wire is at position 23 of the X5 connector and position 13 of the x7 connector at your BCM.
The relays at the X51L fuse block are the printed circuit board (PCB) type. I’m aware of only one part number for that fuse block, so they should be there.
While you’re checking for wires, look at the X51L - X1 connector, pos 15, 20, 28, 33. You’ll need to remove the connector cover to see the wires. On the X61A junction block, check the X5 (pos 25, 29) and X8 (pos 16, 18) connectors. My hope is that you have wires landed in all the spots except the X8 connector.
Report back with pics if possible.
Wow, thanks for the explication..
Will try the best and I hope it goes well..
Thanks again [emoji1303][emoji1303][emoji1303]
I have a 2015 Yukon SLT. Here’s a pic of my adjustable pedals. Arrows are pointing to the motor and cable that adjusts the pedals. Would you post a pic of your pedals? I’m curious if adding the adjustable type will require replacing the whole bracket.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
