Autometer DashControl Display Controller
Has anyone used an Autometer DL1061U DashControl Display Controller? Can it only show extra info on your DIC or can it also display on your radio display?
  • 3 weeks later...
I'm still interested in the autometer device. I like it in the dic of the dash. But no one knows how it works. Or in my case if it works.
My mpvi 2 gives me way more data then anything else on the market.
This video from Autometer says all of the above:
I'm intrigued but I'll let others hammer on it for a while before I drop that kind of money on it.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
