2015 chevy 1500 shocks.. w/ 6.5" lift
Bought my truck as it sits except different tires. It has I believe a zone 6.5" lift. Bought with 11k miles now at 78k. It had the lift on it when I bought it.
I believe it is time for shocks. Alot of creaking and croking on take off and and flexing of the suspension.
What shocks should I get? Not trying to spend an arm and a leg. I will need longer than factory shocks.. right? 9b16279cb0bf1ff48f48decd1b7cf43b.jpg
Sent from my SM-G955U using Tapatalk
  • Replies 31
I mean its started in the last 20k miles. And its when the suspension flexes.
What else is going to make that noise? Its got blocks in the back. And a strut spacer type deal up front
Creaking and groaning is probably not the shocks.  Have you retorqued the lift components to make sure everything is tightened to spec?
See my post above lol
If you're still using the front lift spacers with the zone kit, stock length shocks up front. Rear shocks would be longer, yes.
You can replace the fronts with full length coil overs and remove the spacers though, if you wanted. Would give a nice ride, but a bit more costly.
I'm probably going to be a tight ass and not remove the spacer. I'll snap some pics
Front look to be Rancho. Rear ??
I'm wanting to change them myself. Do I just measure from eye to eye?a6c10319c760b522f08c1cf0d65f3e21.jpg17cfd346ab46cad6b879af9f65153ca5.jpg
Yuck! You’ve got stock Ranchos, get rid of them immediately! Look at Bilstein 5100 up front and rear, re-torque everything, grease up what needs greasing and you should be good to go.
Your rears are junk too, look to be basic junk pro comp shocks, off with their heads. Bilsteins make 5100’s for your application too.
But what size do I need... that's what I'm getting at. How long?
Most applications go up to 6" lift. Mine is probably 6.5in front and 6 or 5.5 in the back. Just get it close or?
I can’t tell you what you’ve got, you’re asking me to guess? Go measure your rear block and take pictures of your rear leaf springs and send that to me
Btw, pic of your leaf springs sideways showing how many you’ve got
Your front shocks can just be swapped with new Bilstein struts
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
