Torque Converter for 8L90
Denali34
what's the part number on this TC? any specs?
you should install a small pipe plug in the TC, so you can drain the fluid out at oil change intervals, you only need one and shouldn't throw the balance off much.
Pro Series Billet Torque Converter Converter Diameter - 265mm - 10 1/2"  with 2800 stall
  • 4 weeks later...
On 2/18/2020 at 6:36 AM, Alex214778 said:
Anyone can help me with the shake and shudder .
i don’t know what I have to do
some friend advise me to change the converter and some says the flash will be the right option?
Flush the transmission & put the new fluid in that’s listed in the TSB. If you’re still under warranty your dealership should do it.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
