2014 express 1500 van
Michael Dees
Anything is possible ... but the question you should be asking is, "Is it easy?" The answer to that is a resounding, "NO."
To make your life easier with today's computer-controlled junk, make sure if you get a used engine, you get EVERYTHING with it - injectors, throttle body, wiring harness, computer and even the transmission. That will make for the easiest possible swap.
Is it possible to swap a 4.3l v6 for a 4.8 or 5.3 l v8
The 4.8 would be less HP and the 5.3 is 55 more. Make it E-85 compatible. Tunes, maybe a gear change etc.
