2014 Silverado trans swap
Hello I’m looking at a new motor and trans for my truck. The truck currently has a 6l80 and this engine comes with the 10-speed. Does anyone know if it’s possible to run this trans. I imagine I will run the tcm from that trans but what about communications to the bcm and the rest of the truck.  I have hptuners and gm dealer tools. If you can point me in any direction it would be helpful too
No, you can't really do that.
Either there is no way to unlock the computer for the new engine (6.2/A10) or even if you did get it from a yukon/escalade from a year or two ago there is still no way to make it all talk with each other nicely.
Nor can you make a the A10 TCM work with your 2014 E92 computer.
You'd have to swap the PCM/TCM from the new engine and transmission in, then figure out if you can make it work with your BCM/ABS/TC/Canbus system. You'd need to be a wiring genius to figure all that stuff out.
