3 hours ago, KennyMcCormick18 said:
I have an issue with my door locks too I have figured out it is only when it's around a certain vehicle it effects two different GM vehicles at my house so far there is no tpsm issues but the car effecting it does have a tpsm issue. Not sure if this helps but could give you something else to look at.
Oh My God! They killed Kenny, you Bastards!
Someone had to be the first......
Haha I don't get that near as much as I did 20 years ago when I made the screen name.
There are still diehards out there like myself, have a stack of dvd's that I need to sit down and watch someday.
I'm having a problem with my 2015 GMC Sierra HD.  The Remote Control door lock and start no longer function.  The Tire Monitoring system no longer functions.  I've purchased a receiver from my GM dealer with the assumption that the original receiver has failed.  After reading this line of comments, I'm a bit depressed that no one has found success solving their problem.
I was happy to find this line of commentary just to find our where to locate the receiver.  I'll work on exchanging the receiver this afternoon and see if that fixes my problem.
Looks like I've joined the club. Too busy to go hunting so I'll just follow here and hope for a breakthrough.
  • 3 months later...
Same issue here.
Watching for someone to have found the location of the issue.
 I found a service bulletin of the same issue on newer models of Chevys.  In the bulletin, they describe the intermittent problem (like I have) means the trouble is closer to the "antenna amplifier module" .. but looking at the diagram on my phone doesn't make the location clear.
https://static.nhtsa.gov/odi/tsbs/2017/MC-10139215-9999.pdf
I will go poking around and report back if I find anything.
Anyone know if the module has an internal antenna or an external one and were it is? Been looking around and haven't had any luck yet
Finally got mine fixed.
My truck is a 2014 Silverado double cab with the 4.3 V6.
Neither my key fob nor my TPMS would work. I replaced the RCDLR and that didn't work. Followed some wires and didn't see anything broken, so I took it to a good mechanic. They found that there was no power going to the RCDLR, so the first thought was a broken wire somewhere in the wire harness. Normally the fractured wire would be under the door sill where people step to get in and out of trucks - that seems to be where most broken wires are found.
There was no breaks there so they traced the wires to the BCM and there was no power coming through BCM on those pins. Decided to replace the BCM before more things started to fail in it since they only ever fail in one direction. Power was now going from the BCM to the RCDLR, but still wouldn't work.
After a lot more diagnosing and time they finally found that the shark fin antenna had been leaking. That is par for the course on these vehicles, but doesn't normally cause critical issues it seems. There was never any wet spots on the headliner in the cab, so I never noticed that it even had a leak unfortunately.
They found that the leaking water was getting into the connectors and causing issues with power going to and from that particular cluster in the BCM. Those 20 or so wires had corroded badly and were causing incorrect voltages, arcing issues and other problems around the BCM. If the truck was suffering with just a lack of key fob and TPMS I would not have fixed it, because it was a stupid amount of money to spend on an 'accessory'. I would have just replaced the leaking antenna myself and sealed it better. Since I didn't want to cook my new BCM or cause any more damage down the line where the truck may just not start anymore, I asked them to go ahead and fix it.
They basically bypassed the corroded connector X225 near the BCM, replaced the antenna and sealed it better, and replaced/cut back any corroded wires so that they are clean and don't cause any more shorts or arcs.
This fixed the key fob and TPMS issues thank the Lord.
Only took about 10 months and way too much money to figure out, but I hope this saves someone money and time down the line.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
