Crank shaft and balancer
Hello i have a 2007 gmc sierra 1500 classic with the 5.3 vortec. Flex fuel. Engine code, L59. Previous owner of the truck replace front main seal. And while he was installing the balancer he stripped some of the threads in the crankshaft. But not completely. The bolt still screws in. But not easily and the bolt looks like it is not centered on the balancer. He did not use an install tool. He hammered it on  and then tried to use the bolt to suck it in  but the boat was just stripping threads in the balancer was not moving. I thought that I had a rod knock going on. But I believe it is something to do with the balancer. I get a ticking noise that goes with my RPMs once the motor is fully warmed up but it only happens every few days. It's more of a ticking noise than a knocking noise. I am not sure if the crankshaft is messed up or if it is just the threads for the bolt in the crankshaft. I have a video and a picture I will upload. I'm not sure if the balancer is on completely straight either. There is a slight wobble. But I do not get bad vibrations while driving. Do I need a new crankshaft? Do I need to read new threads in the crankshaft? What is the best thing I could do? If I could get some comments in help that would be great thanks.
I don't think you'll really be able to know without taking the HB off.  If the HB itself hasn't damaged the end of the crank, maybe you can drill out the end of hte crank and put in a helicoil or timesert.
If the crank is damaged by the HB, then I'd just put it back together (fixing the threads), and if/when it eventually fails, just throw in another used engine, as you basically need to rebuild the bottom end to put in another crankshaft.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
